Redhorse1947
After several years driving an un-restored 1934 pickup (59ab motor w/alternator mounted fan & single 5/8” fan belt) I began a rebuild. I will install and 8ba (Mercury) with 59ab heads. I have read all the info about plugging the water by-pass holes in the head and block and using 1948 8RT truck water pumps. My question is “why” 8RT pumps?
The old 59ab motor used 78-8505/6 pumps lubed from the block. I realized an 8ba does not allow for oiling the water pumps but when I use 8RT pumps it moves the wide pulley center line forward an additional 2 1/8” and now the alternator w/fan won’t fit and even if it did would crash into the radiator.
Can someone that has installed an 8ba in a 1933/34 pickup tell me more about the:
water pumps or
pulleys or
alternator or
fan you used to complete the 8ba installation? Pictures would be WONDERFUL.
water pumps or
pulleys or
alternator or
