stude333
I havent found any serial numbers on the frame yet. I did notice that the passenger side frame rail has the steering box holes. none on the drivers (left) side;does that mean anything? I looked along the drivers side rail very closely at the spots where it should be, even sanded it down lightly. the numbers on the paperwork start with 189##### which looks right for a 1934 pickup. could the numbers be by the steering box holes on right side? since the frame has been boxed in the front with a lot of grinding maybe the old numbers were ground off. I read somewhere a lot of commercial frames only had the numbers in one spot anyway. also any thoughts on how to check the numbers I have on the paperwork to make sure the numbers are clear(not used on another 32 somewhere here in Calif. . the verifiers i talked to need to see the vin(serial numbers on the frame) any thoughts ideas greatly appreciated FRankie
