uncle buck
When converting a 1934 to hydraulics brakes, what rear hubs and drums would I use? I am also considering using Boling Bros reproduction brakes
Thanks
Thanks
Thanks
I BELIEVE anything 1935 thru 1948 because of 1-3/4" brake shoes from 1935 onward. 1934 shoes are 1-1/2" wide.
Coop
Yes, you will.
If I didn't go to Boling Bros I would use '40-'48 Ford brakes. Remember pre and post war were slightly different and I would prefer the post war but at least make them all the same. I have them on my '32 and they went on and work great. Also remember you are going to need wheel spacers if you run the '34 wire wheels (or any '28-35 wire wheel) on later drums.
See https://www.fordbarn.com/forum/showthread.php?p=1286293&posted=1#post1286293 for the reason the spacers are NEEDED.
Charlie Stephens
Thanks
