1934 headlight bracket
This?
https://www.blueovalclassics.ca/ima...89f75e37/4ffa9ca208cbeb6dc6ad82a580bf2ed9.jpg
Listed as a Model A part
Part number 3153969
Model A Ford Headlight Clip - U-Shaped - At Bottom Of Bucket
$5.99 ea
NEWARRIVING SOONEstimated Ship Date 06/29/2023 (If Ordered Today)
Model: 3153969
0 reviewsWrite a Review Add to Wish List
Sheldon,
The one depicted in your #2 post will not work in a '33-'34 headlamp as the flat area is too short. the length of the flat on an original '33'-34 rim catch with the small hole in it is 3/4-7/8", whereas that dimension on a A or '32 rim catch is only 3/8". At least one vendor carries a version long enough to accommodate the small hole for the rivet, but not likely one of the Model A vendors.
Anything left from yours to use for a pattern to duplicate ? The 2 mfg ,Drake and Vintique do not list those parts.
Get the short bracket, weld an extension on, metal finish it, drill a rivet hole, and paint (or plate) as needed. That's what I've done in the past; probably been easier to build one from scratch; but I had picked one up not knowing it would be too short and was determined to use it.
