gz
- City
- Dayton
- State
- Ohio
- Price
- 32,500.00
1934 FORD DELUXE Tudor # 18-1168132
This 1934 Ford V-8 was purchased at Hershey in the late 80s by the former owner. It was a very original car that was upgraded by the last two owners.
The engine is replacement, 1937, 21 stud with the desirable insert main bearings with the water pumps mounted in the block. The former owner added an original Offenhauser dual manifold with two carburetors, dual Red’s headers with Smithy’s mufflers. Recently, the engine has had the engine pan has removed and cleaned, the cylinder heads were decked, new gaskets, etc. The radiator has been removed and flush and has new water pumps. The gas tank removed and cleaned. The carburetors and fuel pump have been rebuilt. The electrical has been restored and includes distributor, NOS starer switch, generator with solid state cutout, new wiring as needed, rear LED lights. All the electrical works well.
The 1937 engine was used with the original 1934 bell housing which has the original VIN which matches the VIN on the frame.
The original 3:78 rear end was flushed, and fluid replaced. Correct ’34 shocks/linkages rebuilt. New spring shackles front and back. Brakes adjusted. Coker Classic 6:00/16 bias ply WW tires are dated 2019. A new 3:54 ring and pinion setup is included.
The car has an extremely rare set of original spider hubcaps on 1935 16" wire wheels.
The interior has new upholstery with correct material on the seats and retains the original side panels and headliner.
The body is in excellent condition. It is solid, straight and original. The doors, fenders, hood, grill fit properly. The paint is excellent through out and shows extremely well. The car has been completely polished and detailed. The chrome is in very good condition. The grille is in great condition as well.
The car has a current title in the owner’s name with the correct VIN numbers.
This is a great car. It is ready to drive and needs nothing to enjoy. It is solid as a rock and is well sorted.
The price is 32,500.00.
Call me directly at 734-730-4274 or email directly at motoringicons@hotmail.com for additional information and photos.
Agent for the owner.
Thank you.
Thank you.
