- City
- Firestone
- State
- CO
- Price
- 30000
I picked this up last year and have been working on it since.
New Brassworks 4 psi radiator, electric fan, new tinted glass, new tires (5), sound deadening added, trans has 1940 gears, new ring and pinion (3.54), new gas tank and lines, all new wiring (except dome light), 12V negative ground with alternator. Driveshaft is rebuilt. Speedometer is rebuilt. LED headlight bulbs in original housings. Turn signals added. Front seat belts added. Electric gas gauge installed, original in a box.
Engine was rebuilt by previous owner. Compression test numbers are in the engine pictures. Runs well.
I painted the underside with Rustoleum while I was working on the driveshaft and rear axle. The only rust issue is the bottom of the driver's door. The rest of the car is solid. There are bumps and scratches around the car; it is not perfect but is a solid daily driver level of condition.
Original interior is serviceable.
Clear Colorado title in my name.
303.727.0106
303.727.0106
