1934 Ford Truck Project
kwmpa
Williamsport
PA
Price
in add
Price reduced 1934 Ford Truck Project
Well its come down to me needing money to finish my 3-window so im putting this up for sale. I dont want to at all but i need to move this project forward.
Here is the run down from the ad I bought it off of.
Nice '34 cab, chopped about 3", door chops are just tacked. Nice shape overall, comes with all latches, regulators, tops, handles, etc... Someone welded the hinges to the sheet metal, needs some work in that area and a few dents worked out. Rear bottom bead needs a patch panel. A p.o. tried to "repair" the door bottoms... I removed the driver's side abortion, looks like they just need new bottoms and lower patches. Subframe is intact and workable, has a sheet metal floor tacked in(bitchin?). Firewall was recessed, it has been returned to stock. The weld job on the cab is a little ugly...someone tried to stick weld it to cold...there isnt a lot of warping its every workable...
Nice bed, all apart, needs one stake pocket and rear crossmember that the tailgate mounts to. Front panel is a little crusty probably going to need a new one, two bedframes.
Original '34 frame, boxed, pinched, bobbed, and has 2"x4" tubular rear kickup and 3" round rear crossmember, model a front crossmember, no center xmember yet, Nice F1 Steering box installed but no draglink yet, 36 front axle with '34 spring hung behind, split bones, etc... model a rear
Comes with all latches, handles, regulators, door tops, nice cowl vent assy, a really straight dash, super nice grille with straight stainless trim, good hood, '34 radiator, nice '34 commercial headlight bar and buckets (no glass), windshield frame, rear garnish, a set of F1 pedals.
The pictures are as follows and just mocked up for pictures the truck is currently disassembled it needs finish welded and fabrication work...Great start for a project. I wish i didnt have to sell it but I do. Honestly you probably arent going to find another this nice for the price. Have been seeing mint cabs selling for $4000 by themselves.
I have since had the cab frame doors and bed all sand blasted...the cab is in self etch but the rest of the parts are still in bare steel but everything is stored indoors... I have all the patch panels for the cab...including new cab corners, door skins, door bottoms, new tailgate, new bed front, new door handles new interior door handles, new window crancks, all grille chrome, hood orniment. I am asking $5000...i can work on priceif you dont want all the parts i have
see pictures here
http://www.jalopyjournal.com/forum/showthread.php?t=413625
