stude333
could anyone measure the location from the center of the front spring(axle) rearward to the center of the steering box hole in the frame. my frame was boxed and everything welded closed and ground smooth. i am going with an f1 box and want to use the original drag link. so I want to put the steering shaft hole pretty close to the same location. post dimension her or if you could email to stude3@verizon.net . now with the good weather I am back on a roll getting my rod together
Thank so much
Thank so much
