Jack Linton
- City
- Osceola
- State
- Missouri
- Price
- $11,500
1934 Ford Model 46 pickup truck frame - original uncut - both front fender braces bolted + front bumper attached - V8 crossmember
Barn found Osceola MO 64776 - C147005 paperwork - 40-6050 heads + 3-tray oil pan included
• 1955 Colorado Certificate of Title C147005 — Make Ford Year 1934 Model 46 Body Type Pickup Motor B18 874878 — El Paso County — Issued Apr 12 1955
• Specific Ownership Tax Receipt — 1934 Ford F-MIN 2500# — Motor B18 874878 — Title C147005 — 1955 — $1.50
• Taxpayer's Copy H12169 — Handwritten "34 Ford Pickup B18 874878" — 1955
• Original Dept of Revenue Envelope — Denver Apr 14 1955 meter — Handwritten "34 Ford Pickup" — contained title
Motor No. matches all four documents.
History: Purchased March 26 1955. Original Colorado Springs municipal green still on cab, doors, bed bulkhead, taillight housing, running board.
Frame: Original '34 frame, uncut, unboxed, all rivets.
• BOTH front fender braces still bolted to frame horns — factory bead, not bent, not repop — driver and passenger
• Front bumper still attached to frame with original brackets and bolts — correct for Model 46, pickups had front only factory
• Both front crossmembers solid
Cab: Original '34 cab, both doors with original glass and regulators that still operate, original outside mirror on driver door, cowl vent intact, dash rail intact, all cab glass present, taillight housing with green under rust. Floors need work as expected.
Engine Parts: Pair of 21-stud flathead heads — B18 series 1933-36 — with valves and springs. Block not included, heads only. Core condition.
Small Parts Original to this truck:
• Dimpled '34 running board — green under surface rust — diamond pattern
• Domed 4-bolt floor inspection cover
• Diamond pattern brake/clutch pedal pad
• Steering column firewall seal, bed wood block, pedal bracket, body mount spacers
• 5-gal bucket of original hardware — shackle bolts with square nuts, body bolts, radiator clamps, etc. — all from this truck, not hardware store replacements
What it is: Project. Needs floors, wood for bed. All bracing under bed is solid. What it is NOT: Cut, boxed, or molested. Has all the small brackets most '34 frames are missing.
Location: Osceola, MO 64776. Can help load with tractor.
Price: $11,500. OBO. No trades. Clean paper trail in hand.
Text only: 618-741-5407
