thirt4
Ok, stumped again. This re-assembly deal is not what I expected. It was all so easy when all the pieces were removed last summer.
Now I must ask... and real good photos would really help too...
Just how do I get the horn back on the mounting tab and then wired to or with the headlights? Maybe just how does that horn go back on the mounting bracket that bolts up to the headlight stand?
Also, where do the rubber grommets go? They were in the new Vintique kit so they must belong somewhere.
Then, once the horns are mounted on the headlight stands, which route do the horn wires take? Do they go through the headlight stand bolts?
Wish this project had moved a bit faster but hey... I got it moving a little bit still.
Thank you.
Thank you.
