1934 Ford, Fordor Deluxe
Michael Marti
Simsbury
CT
Price
40,000
1934 Ford Fordor, Deluxe
Model 40A, Body 73B
Mileage since refurbishment 4800 miles
This car, having an all steel body, has been completely refurbished over
a 6 year period, ending in 2011. Most stock elements have been
retained to preserve its original natural attraction. Updating has
been done to enhance road safety and dependability. This sale includes
a freshly overhauled spare flathead engine, spare carburetor and other
parts. Included also is a library of 1934 Ford books/manuals and
complete file of work done and parts installed In the car.
In essence, you are being offered a turnkey package of car, spare parts
and background literature verifying the integrity of the refurbishment while providing a carefree, safe and enviable driving and ownership experience.
Interior Highlights
Upholstery was completely redone using a LeBarron Bonny 1934 Ford Mohair kit. Front seat is a built-up of solid foam while the rear is a new Ford spring seat. Floor and door panels were sound deadened. Custom rugs were made and an acoustic treated firewall panel applied. Three point seatbelts installed. Garnishes and dash wood grained via the Water Emersion Technique. All new gages and gage senders from Classical Instruments were installed including a tachometer, voltage and ammeter gage. Front and rear seat courtesy lights installed. Door pull rings and locks installed on all doors. Steering wheel is NOS with a steering wheel needle shaft bearing installed. Turn signal switch and defroster vents are VW parts selected to compliment interior.
Exterior highlights
The car’s steel body, was found to be in excellent shape thus requiring little body work. It was primed, painted black and top coated. The under body was sand blasted and spray coated with rubberized undercoating. All new glass, window runners, slides/rubber water proofing guides and SS beaded fuzz strips were installed. New Drakes running boards, chrome work installed. New roof top kit installed. New headlights, tail lights (LED) turn signal lights front and rear were installed.
Electrical Highlights
All new, individually strung, wires (no kit) with a hot and switched fuse block under hood were installed. A 12 volt negative ground system with an Optimal battery, a security system and emergency flasher has been installed. A Mallory electronic ignition system, ignition coil, ballast resistor and power cell installed. Alternator, starter motor, starter switch (dash mounted) are new.
Mechanical Highlights
The engine is an overhauled 59AB V8 flathead bored .060” from stock. Crankshaft is a 4” kit from Speedway Motors. Camshaft is an Isky 77B mild race cam. Carburetor, water pumps, radiator, fuel pump, gas tank, oil pump, clutch are new or refurbished. The transmission is a 1939 Ford reconditioned. The differential is a 3.54:1 option from factory. Shock absorbers, front spindles, Pitman arm, kingpins and steering box either new or refurbished.
Miscellaneous Highlights
Wheels are 1935 16 inch Ford spokes, sand blasted, painted and run out checked. Tires are new Diamond Back Dunlap 215-70R. Brakes are hydraulic from the Early V8 Garage made from 1939 cast iron Lincoln self energizing brakes. Dual exhaust system including Fenton cast iron headers, stock mufflers and resonators are installed.
A complete list of spare parts and literature, as well as detailed specifications, are available upon request. There are ten You Tube video’s of this car from 1-10 and can be seen via 1934fordor1,2,3 etc. This vehicle may be listed elsewhere and we reserve the right to end this listing at our discretion. For those buyers who may require a vehicle transport, we recommend the use of Auto Bahn USA. www.autobahnusa.net
Please contact us for any questions you may have. Michael Marti 860-651-1785.
