1934 ford door swap
rockyski
New member
Hi my first post my 34 ford 3wd coupe doors are shoot can I swap them with 34 ford tudor sedan doors if I swap top window channel or other words is the bottom three quarters the same.
Thanks Darryl Ont Canada
This has been done before . Tudor , Victoria & 3 w coupes all have long doors . The thing to watch out for is inner door handle placement . Early 34 & late 34 are not the same . Early has the handle in front & late has it in the middle of the door .
The middle hinge placement is just a little higher/lower by like a 1/2" (can't remember which) from a 3w to a sedan door. So if you iron that out that and the obvious rear of the window frame you'd be good to go.
I might add that in the past 2 yrs. I've only seen 1 set of 3w doors for sale. They were 33' 3w doors in good shape. They were both bare needing the bottoms patched. I seen them at the LA Roadster Show swap for $2700 ea or $5000 for the pair. I know they are rare but c'mon you have to be realistic!?!?!
