1934 Ford 5 window coupe
dodgerb440
Greenwood
Arkansas
Price
20,000
1934 Ford 5 window coupe SOLD. Thanks H.A.M.B!
SOLD 1934 5 window coupe. late flathead bored .125 new Offenhauser pistons, rings, adjustable lifters, new stainless valves with new style one piece guides and seals. block has been cleaned, shot peened and magnafluxed, needs to be honed to piston size. It comes with turnable crank and extra late engine. New Mercury Canadian aluminum heads. Edelbrock 4X2 intake with rebuildable stromberg 97 carburators. All stock acessorys.
T5 transmission from Firebird with S10 tailshaft housing. Late flathead one piece stamped steel bellhousing modified to bolt up to T5 transmission with no adaptor, flywheel, throwout bearing, fork, pressure plate, new clutch disc, and starter plate dust cover. 1946 Ford pickup open drive rear end. Stock 34 rear end.
Original 5 window coupe body, never been off original frame with good title and bill of sale. All widow garnish moldings and dash panel. New quarter panel patches and rockers instaled also new panel below deck lid. New top and roll down rear window wood kit. New complete lightly tinted window kit. New complete frame boxing kit. Tube type drop axle with new mono leaf spring and shackles, round back ford spindles and hydraulic brakes. Posie dual leaf rear suspension kit is not installed. Two original 34 grills need straightend and plated. Original headlights. No fenders.Nice pair of original running boards that need new covers. Original front inner fender panels. Original bumpers and brackets. Original wire wheels. Set of Motor Wheel brand heavy duty bent spoke 17 inch accessory wire wheels.
Priced at $20,000.
Thank you.
