1934 exhaust system availability??
40a-760
Are there currently any correct 1934 exhaust systems available on the market. Has any barners used those advertised by Drake and Macs. Any guidance and suggestions would be greatly appreciated.
Thanks
Walt K in PA
Front (repro) pipes are crap. Tail pipes are decent. NONE are concourse correct.
Kube,
Thank you for the info on the 'available advertised systems'. Does anyone do custom work that you are aware of that might have access to a correct system to duplicate? I have nice headers and clamps, but am in need of everything else.
Thanks again
Walt K. in PA
If you have nice front pipes and are (apparently) not real concerned with authenticity, the repop pipes will no doubt work well for you.
Around here there is ONE and one only shop i trust to do good custom bending. No doubt there are some in your area as well.
Kube,
I used the wrong term for what I have. The exhaust manifolds, not headers, are nice early takeoffs as are the exhaust system clamps. The car is being done as a concourse restoration, so the exhaust system I am hoping to duplicate would need to be correct. As you suggested in your reply, there are shops in the area that fabricate exhaust systems, but I have no info to provide them to make a concourse level system.
Thanks again for your response.
Walt K. Out of answers in PA
Kube,
You might try Mike McKennett at 503 257-2433. He made a few beautiful systems for the '32 a few years back and understands concourse level restorations.
Charlie Stephens
Thank you all for your kindness in responding to my inquiry. I will be following up with Mike McKennett tomorrow and will post the results for those also in need. My fingers are crossed.
Walt K. Hopeful in PA
