Karl
In the next month or so I intend to pull the dash on my 34 Fordor
My dash Needs painting and One of the instrument mount studs has broken off and needs fixing. While I'm there the wiring under the dash looks messy so will be easier to clean up with the dash off . i may replace my Glove box radio with an ashtray unit but I'm undecided currently.
The questions n is what is the easiest way to deal with the Throttle and Choke knobs . I assume that the rods won't just pull out with the dash if disconnected form the carburettor . I have found the connectors under the dash are they threaded or crimped on? Someone suggested I break the knobs off the rods and replace them after the new dash is in -sounds drastic , wrong and not where I want to go.
Thanks for your advice -Karl
