Steve Staysko
The brake light switch on my 34 works intermittently does anyone know where I can find an NOS one or can they be taken apart, repaired and cleaned any suggestions would be appreciated?
Well I replaced my brake light switch with an NOS one which has the brass bushing on each end of the housing and guess what it works then it doesn't work. So I was thinking last night when I was kind of a sleep and my question is does the brake light switch actually ground to the brake and clutch assemble? Then if it does I'm thinking that I have too much paint between the brake light switch and brake and clutch assemble and I'm not making ground? I'm I correct and do I need to sand off some paint so that I have a good ground?
