1934 5 window coupe door glass channels
uncle buck
Can someone please show a picture and length of the door glass channels on a 34 5W coupe? Are 33 and 34 the same? Are 4 door front the same.
Thanks, Dave
'33 & '34 are totally different do to the vent provision on '34s.
Fords hardware & trim book shows the same part for 5W (40-770) & 4 door (40-730) front doors.
Top channel is '33 while the bottom is '34.
United Pacific makes reproductions of the 1934 but are longer to fit the 3 Window/Tudor. Simply cut the end to length. I think they have 1933's also, or you can cut down their 1932 Tudor ones.
Thank you Rich. Obviously the regulators are going to be different too.
Regulators are different too.
One advantage is the '34 door regulators are the same as '35-'36 Tudor quarter window regulators so there are usually a lot of good used ones around.
