1933 V8 Parts
Graham Freeman
I have had for over 50 years (and realize I will now never use them) what was supposed to be a NOS 1933 fuel pump push rod and a NOS early starting crank bearing 40-5461-R with the ears for the early style fender brackets.
I wish to move these on and want some idea of value?
Any ideas, I am in NZ.
Cheers Graham.
Graham,The push rod worth something ($75?)as it fits late 32-33 all.Renners Corner has them listed so that will give you an idea.The crank bearing is early 33 only ,not much demand.$40 maybe.
As you know "Early" 33's are mighty mighty thin on the ground. Thus the "need". Unfortunately
I do not know why this should have ended up in NZ as we definitely never got any of the early 33's in NZ.
Also I had a relatively early 3 window 33 here and that had a similar crank bearing but the ears were not drilled for the fender brackets.
