Try turning the wheels full left or right.
Paul in CT
I don't understand your comment, please help...You have to detach the front axle radius rod assembly (what I believe you refer to as the "center Y frame support") where it is attached to the center cross member and lower it sufficiently to drop the pan clear of the flywheel.
Local service stations have NO IDEA how to work on these antique cars!Take it to a local repair station GoodLuck
The Y section or "wishbone" is fixed to the frame at the rear with a cap and two bolts and nuts. Remove the cap. Lower the rear of the wishbone until you have enough clearance. If the tie rod is in the way remove that too.
If you still need help it would be good if you could post some pictures of the problem.
Mart.
Nothings making sense to me, Frank, without some photo's it's hard to offer advice. I have a 33 and nowhere are there "springs with wires" except for possibly the radiator mounting.
Mart.
You wishbone is clean,,,Mine have ywo set of spring attached to rods that go to the steering.... To maintain steering resiliance???? Don't knowFrank,
Just posted this on your underside view request. Does this help at all?
Keep 4-banging!
