1933+ horn question/help please!
smittyj23
Hello everyone! New member here. Told about this site by a very helpful guy.
I need help with what I believe is a Sparton CL-4 deluxe. I tried uploading a picture of it 6 times to no avail. Could someone help with the following please:
1) a picture of how the wires are connected under the bell and
2) where can I purchase the bracket and screw that the bell attaches to? Wiring too possibly. I've sourced a bell and external mounting bracket.
Thank you for any help.
I can email someone a picture of the horn I have if that helps.
Slide the external electrical wiring terminal under the metal clips on the terminal board and they will clip in place. Have to raise the clip to release the terminal. Third Gen Auto has the other parts you need including mounting brackets and all screws. The photo below showed up on your last posting. I think it is a 35 horn but you can clearly see the terminal block at the 6:30 position. It has two sides and one wire goes into each side. push the wire terminal straight into the end.
Another
455267
Don Rogers put this pic up in another thread on horns.
454565
