I believe that the problems your having with the King-Seely fuel gauge,is not in the gauge,but in the sender in the tank.The two lines that run from the cups have side holes that need to be real clean,so the gas will pass thur the two lines.But also just as important at the bottom of the sending unit is the round cylinder,with a small pin hole on the very bottom,this pin has to be clean.That round cylinder,after cleaning,must be free of inside scale,if not you will not get a true reading,because loose scale from inside the cylinder will continue in time to plug the small pin hole.I hope this helps.E.P.W.
