1933 Ford Pickup
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
I have noticed some 33 Ford pickups use a
stainless grille trim. Does the stainless trim off a 32 commercial work or what year would fit. Thanks for your help
They might just have installed a 34 truck grille that has the stainless and the holes for clips. Other wise I believe the grilles are the same.
Showing my ignorance again, but wasn't the 34 the only one that used a grill stainless trim?
Yes I believe you are correct my friend has
a 33 and he was wondering if the stainless
came off 32 or 34. We are going to get a 34
stainless and hopefully put it on his 33.
I think you can do that but you will have to drill holes for the clips. Maybe you could install it using some of this double stick tape they put moldings on with nowadays.
