1933 Ford Pick Up - barn find
Niwot
CO
Price
$13500
Hi All,
Im selling my 33 Pick-up so i can finish my 28A roadster and my new workshop :-)
This is solid Colorado truck, zero rust (Its so dry here!), was originally built in the 50's as a push truck for dirt track cars. It has 1939 Ford running gear (Trans with dual detent shifter, 39 rear, wide five wheels and brakes, 39 Steering box and cross steer). Comes with a 59AB that is in it - its not stuck but will need rebuilding - missing intake though. Forty Ford steering wheel.
All doors close and open well (For a 80 year old!), all glass intact front screen has a small crack in one corner but still OK. all window mechs, locks intact etc
I have replaced all the wheel cylinders with new parts, I have a new 39 master cylinder and new steel brake line kit that isnt fitted. All drums and bearings are perfect. It had a weird swing pedal for the brake that was dangerous, i have a very good set of 33 pedals that goes with the truck to put the cylinder under the floor
Comes with the small bucket seats and the original bench seat.
The truck comes with a current Colorado Title and registration in my Name, assigned 33 Plates.
This was last used in 1964, then parked in a barn.
She comes with two sets of wheels, the set of 39 ford 5" wide wide five with wide white rollers (These tyres are rollers ONLY given they sat since 64!). She also comes with a set of V8 60 wide five wheels with brand new blackwall 550x16 tyres and hub caps.
This enables you to have a great hot rod look with wides and skinnys.
Comes with an exhaust kit with smithy mufflers
Great patina, lots of scratches, worn paint, cowl vent was filled in the 50's she still has the original set of keys still in the ignition!
Original Guide Lights on undropped light bar
Price is $13,500
I also have a very low mileage 53 EAB Ford Flathead with new pumps, Modified lower pulley for early fitment, Navarro dual inlet, New 12v Powermaster flathead starter, Speedway headers, engine mount kit, 12v Alternator and mount for an extra $1500
Few Picks:
as Found:
