1933 Ford BB truck
Post some pictures on your trip . . . love the whole plan and the fact that you're far from new to trucks and Big Rigs!
Will do but I'm going to travel at night - when traffic is low - timing is very important! And I'm getting fully prepared - don't need any trouble!
I have a 30 gallon side tank and whatever is under the seat 15 gal? I figure 8 mpg pulling the trailer at 55 MPH. Gas is down to 4.23 and I can't believe it but I think that's a deal after all the abuse we get in California!
Tools, coolant, oil, jacks, spare tires, lug wrenches, head lamps, safety triangles, chains, binders, straps, registrations, insurance, glasses, jacket, Hi-Lo, big pry bar, extra ignition points - etc.
Back home safe. Trailer somewhere around 10,500 lbs and around 2,500 lbs on the truck. I stayed under 45MPH and off all crowded roads.
It would have been a great trip but the hitch isn't strong enough and I need to redesign it and I was worried about it so I stopped a lot to check it.
Also I think I can make the truck breaks better. I'd like to true up the drums a little and check all the linings to make sure they're clean and soft enough (high friction) material.
529890
529891
529892
I wonder if you took a brand new Ford BB off the lot with 3,000 lbs on it and did a brake test - would the wheels skid on dry pavement or not?
Chevy43
I must admit you have a pair? To haul that with your truck! Thanks for the pictures and updates! My guess you got a lot of looks!! :)
Regards,
Chris and Cheryl
To be honest,
I'd rather haul with something else but my dad passed and I'm trying to save stuff fast and this is the only truck that is big enough and yet small enough to go up his road at the moment.
That's A 1943 International on the back he let me drive to high school a few times after doing work of some kind to earn it. There's more cool stuff I'm trying to save.
Also the BB had deteriorated badly and I think it's better to use and enjoy something than let this happen to it!:
It looked like this a couple of months ago. That's all wood rats - they are the worst and so terrible at his house!
Here's the inside of the International - which I also got running after 15+ years of sitting.
It's a good thing we get to have pictures with the internet. Otherwise some folks might think you were 'exaggerating a bit' on the details. Holy Freaking Cow! What a trip!.... And those damn Rats!!!!!
Ran another 300 mile trip in and out of the Bay Area. This GVW was around 18,000 to 19,000 lbs. when I got to the flat area of the freeway I used that instead of back roads since it seemed to run fine and felt good at 55 MPH.
I built a strong pintle hitch since the receiver hitch that was bolted on was weak and failing. I built it out of 4x7x1/2" angle iron bolted in 5 places on each side and up through the bed tie down plates.
Nice cargo on trailer, an IHC USMC M-2-4 1 ton cargo truck. Is the cab original or transplant? Most were open cabs, but a few were built with the K series cab. Wasn’t unusual for a cab transplant from a K or KB IHC.
I had an IHC M-1-4 USMC frontline ambulance. That was a .5 ton. Same chassis, albeit a foot shorter and a few less spring leaves. Stout old devil. The front axle was a cast, crudely machined chunk designed to accept the same 3rd member as the Eaton derived civilian K series 1 ton rearend.
More pics please.
Top pic, the late great USMC Korean War vet Shirley Laird of North Bend with his restored IHC ambulance. Other than the M-1-4 cargo, he had one of every IHC military vehicle built, he restored them himself. Bottom pic is the ambulance I pulled out of the Oregon mountains. Took it down to the frame, had it half done before I sold it to a collector in preparation to moving back to my home state. Not an easy task finding engine parts for the Green Diamond flathead six. Shirley Laird was a blessing to meet. He didn’t have the original rear door hinges, my pile did. He borrowed them to have castings made. In return, I got to raid his parts vehicles. Transmission was the same spur gear T 9 as early Fords, but where does one find guts for an obsolete transfer case, other than Shirley. Sorry for the rambling, I have a soft spot for old IHCs.
