1933 Engine splash pans??
33rds
Anyone know what year / model this engine splash pans are?
Originally '33 V-8 pans trimmed at the front. (Ignore the extra hole in the one in the attached photo.)
Thank you David, but the protrusion at the front end seems to have been there from the beginning, I can not see any welding seam at all. But the protrusion appears to interfere with the engine mount! Strange! Could it be to an early 33 with the 32 style engine mounts?
I believe that you surmise correctly and that the pan was the initial version used with the carry-over (from '32) spacing of 12" between the motor mount insulator center lines.
