Ron in Quincy
I recently acquired a 33-34 Zenith carburetor lower housing. In the 40 plus years of working on carburetors I have never seen a lower housing like this.
Could someone please identify what the application might be ? With out the upper housing, which must also be different, I can not figure how it would work.
The choke lever and plate was in the housing; when in a closed position it covers the passageway; it has a spring loaded valve on the plate; there is no provision for attaching a lever to the threaded end of the shaft so there must be some special arrangement from the upper housing?
It is set up for the standard high speed jet and idle jet like a regular C carburetor (33-34).
I am attaching pictures and would appreciate any feed back.
Ron
Ron
