old28
- City
- camarillo
- State
- ca
- Price
- $850 OBO
This is a complete ready to install 1932 B Transmission case with the model B upper flywheel adapter and lower flywheel cover. Transmission has a complete 1946 syncro gear set from a coupe car. All gears, shafts, bearing are as removed. All parts were cleaned and inspected before installation. Includes new throw out bearing & return spring, clutch fork shaft bushings. Forks, shaft & connector work free and are ready for installation. B case has a 1939 shift tower with correct size forks, double detent unit with new balls and springs. Shifter shaft has new black ball on top.
This transmission with the B flywheel adapter will bolt directly to all model A & B blocks (you must use a stock model B flywheel or a cut down model A flywheel for proper case clearance).
Included in the package sale are (1) new 6 hole shift tower gasket, (1) new flywheel adapter to block gasket and (2) new brass U shims for adapter to block bolts.
Trans has no oil in it sense rebuild so you can check out gears and shafts. Come inspect unit. What you see is what you get.
Price -- $850 OBO
PM All Questions & Replys
Unable to ship but can deliver to a local shipper of your choice.
Can Email 9-12 pictures
Price -- $850 OBO
