1932 steering housing cap (B-3589)
Lincolnville
Which one is the correct upper steering housing cap (B-3589) for a 1932 Ford passenger car? The taller one (in red) is 2 3/8” in height and the shorter one is 1 9/16”. Otherwise, they are identical.
Matt,
I associate the short one with fractures in the bottom of the steering column tube because it does not extend beyond the slot in that tube.
Watch out for BB parts, the tube is thicker than car and that housing smaller dia. I remember? Newc
Newc,
I just rechecked the diameter of opening for both and they are the same. However, the worm gear is throwing me off. The worm gear is 15 for the smaller housing but the larger one is 52. The length of the shaft of for both is 40.83" - matching the length for a 1932.
Matt
Technically speaking, 15-to-1 steering gear sets weren't adopted until 5,000 passenger cars and commercial vehicles into the 1933 model year in the U.S.. The '32-early '33 gear set had a 13-to-1 ratio.
There is no 52- prefix sector or worm gear listed in the various '32-'37 chassis parts catalogs.
Judging from your third photo, your two sector gears have differing ratios.
Newc,
Matt
538898
538899
538900
Thanks to Pete's enlargement, there's no question. The 15 and 52 gears are not the same. The 15-to-1set will steer with less effort.
Agreed. You can't interchange the two. Both sets of gears and worms are worn, so I will replace everything. I just removed the worm, and the rod is in good shape.
