1932 steering arms
wa4ko
Does anyone know where I could get a right hand double ( for cross steer )
steering arm that will fit a standard 1932 axle?
Thanks
Larry
Not sure, would like to use 1928-34 Ford Cross Steer Rack and Pinion and they
told me I would have to find a right side double steering arm for the car. The
older cars did not have a double for steering rod and for tie rod to be able to
both attach??
Larry
I think you should join the HAMB. A lot of info over there. The rack and pinion is not the best idea. Do a search. You can use a tie rod end that has a bung for the cross steer. The rack and pinion steering results in a very wide turning radius. A Vega or a 37-48 Ford box would be vastly better.
