1932 standard
Clowndr
Do standard cars have dash light switches? I remember on some I have taken apart throughout the years having a metal plug in the hole. If no switch, do they have light inter grated in steering switch? Also I noticed that the choke and throttle knobs are black as per standard as as I have been told. Thanks Joe
'32 std and dlx choke and throttle rod knobs are the same color(brownish maroon).None are black.
As deuce lover indicates, all '32 instrument panel knobs were dark brown, be they on a standard or deluxe model passenger car, commercial vehicle, or big truck. Black knobs of the same shape as the '32 knobs were used on some of the '33-'34 commercial vehicles and big trucks.
All V8-powered '32s had separate dash light switches, standard or deluxe. Early and mid-year four-cylinder-powered '32s had no separate switch and the hole for the switch was filled with an engine-turned steel plug button to match the engine turned finish on the rest of the instrument panel. If the panel was black (early Bs, commercial vehicles, and big trucks), the plug button was painted black. Those vehicles without a separate switch had the dash lights connected the head lamp wiring directly and came on when the head lamps were turned on.
Late in the '32 model year, the starter motor was revised and the same starter switch used on V8s was added to the fours. Both the main and lamp wiring harnesses were revised at the same time and the dash light switch was added to the instrument panel.
