FritzJr
I have read that the font for serial number stamping was changed in late 1931. The new font had different character shapes for 1, 6, and 9 to make it more difficult to change or replicate. Supposedly some early 1932's had the old font but all units built later in the year used the new font.
I have had the chance to view a '32 which is currently undergoing restoration. (It is not mine) The car appears to be an unmolested original which had not been previously restored. It has all the characteristics of a late in the year build. The serial number would indicate a unit produced late in the model year.
The serial numbers on the transmission and the frame are the same. However, the transmission has the numbers stamped in the new font while the frame is stamped with the old font. The front and the center frame serial numbers have been found. The rear serial number is not visible due to some rust in that region. Both the front and rear frame serial numbers have the old font. Both stamping have the stars. The front serial number has the 18 prefix and the special dash. The center number does not have the prefix, as was the common practice. The frame numbers appear to be original and not restamps.
The question is whether is it reasonable that the font of the stampings would be different between the transmission and the frame.
