I have a 1932 Pickup with a model B. I have a problem. When I first got the pickup I topped off the radiator right up to below the radiator cap. I learned quickly that was a mistake as it started squirting it out the radiator cap after it warmed up. After awhile it quit doing that, however now it pumps it out the overflow tube. I have driven this everyday for two months, everyday I have a antifreeze puddle on my garage floor the size of a silver dollar. I have a laser temperature gun, here is what I found:
Radiator top tank 131
Radiator fins 135
Radiator bottom tank 130
block 171
head 170
head around the spark plugs 180
Water inlet/outlet down by the starter 152
cylinder walls 182
water pump 157
So its not running hot. I don't know why its pushing out antifreeze. Surely after 2 months of being driven everyday it can't have too much in it. With the stock radiator the inside of the radiator is covered, so I can't see in there to determine how much is actually in there. I checked my oil to see if by chance I had a cracked block and its a brownish just like it is supposed to be. Any ideas how to fix my problem ?
Radiator fins 135
block 171
head 170
cylinder walls 182
water pump 157
