Ed in Maine
To me this is a mystery. The car is loosing over a quart of water in just 1/2 hour of running time. This is what is known:
1. New engine, milled head and block, car has 115 miles on it.
2. This is the second head gasket, carefully cleaned and sprayed with Permatex head gasket sealer, on the gasket, on the head and on the block (all surfaces)
3. The head was torqued down very often to 50 ft.-lbs. After it was assembled, the head was retorqued after 5 minutes of running, then after 10 minutes of running until the torque required did not change from 50 ft.-lbs.
4. There are no bubbles in the water at the radiator cap. I took the fan belt off and watched a calm water surface
5. There are no visible leaks. All hose clamps are tight, there is no dripping in the garage. Where is this quantity of water going???
6. The tail pipe is not steaming.
7. The oil level in the crankcase has not changed. The oil is not discolored or foaming.
Any ideas? Could the head be damaged in some way that I have not noticed? My next step is to see if the water pump is pushing the water up to the over fill pipe when the car is traveling at speed. It is a very aggressive, new, water pump with lots of turbulence above the baffle in the radiator tank. Fortunately it has not over heated.
Thanks in advance for any suggestions. Ed
