toysanyone
- City
- Bozeman
- State
- Montana
- Price
- 895
I will ship this scarce original 1932 Ford car or commercial vehicle firewall to any foreign country in the world. It is too large to ship using Priority Mail International from the United States Postal Service. I will use FedEx Ground to ship it to the port in Los Angeles California. It will then be included as a partial shipment in a larger sea container going to any foreign country.
If you want a good original firewall that was built by Henry Ford and his guys and has not been welded on yet or messed with in any way other than being sprayed with gray primer, here it is. This item has no rusted through or even thin spots on it anywhere with one exception. The top of the flange on the upper rear edge about 15" to the right of the center has an 1/8" wide spot where the edge of the steel has rusted to a sharp edge. The will not be visible when this is installed on the vehicle. It also has some minor pitting in a few spots on both sides. That will also be concealed by the firewall insulator on the inside of the car.
There is a 2-1/2" hole on the passenger's side where an exhaust manifold heater was used many year ago. There are a pair of 1/2" long vertical cracks on the bottom just inside the vertical supports on each side. The backs of the horizontal mounting feet that are often cracked or have missing pieces appear to be fine. The fronts of these mounting feet or flanges are both missing a piece that is about 2" long by 1" or so wide.
Thanks a lot, Bob Woodburn - phone 406-799-1847 in Bozeman Montana USA
