1932 Fuel Tank Sending Unit
1962300
Hello All,
I am working with the following goods:
- Aftermarket Fuel Tank
- Aftermarket Sending Unit (from ISSPRO)
- Feeds a 1930 Essex Fuel Gauge
My Sending Unit has:
A) A failing rheostat; very inconsistent readings on my multimeter
B) A full of fuel plastic float
I sought out & ordered the smallest Sending Unit from Tanks, Inc.
But it is a hair larger rheostat that the opening in the top of the tank allows for.
I can file, or Dremel, the opening out a bit to allow for the new Sending Unit to then drop in.
Or....
I can seek another Sending Unit that perhaps matches this thing that already fits.
Anyone know any other sources for quite narrow sending units?
Picture attached of what I have, on the left.
And Thanks!
I have an Australian made gauge tester which has a variable rheostat which takes the place of the tank sender and has a readout in ohms on its dial. I have used it for years to test dash gauges. Dont know if anything like that is made in the USA. No use buying tank units unless their resistance range matches your Essex gauge. You could look up an Essex car manual to see if they list the gauge specs or take your gauge to an auto electrical shop and see if they have a tester. Make sure you tell them it is a 6 volt gauge. Regards, Kevin.
When I test gauges for the aircraft, I apply a variable voltage to them. Full swing is generally pretty close to system voltage but some work the other way around. Voltage at empty would depend on the voltage drop of the rheostat. Different manufacturers use different ranges of rheostat if the system in designed that way but there are only four or five different ranges that I'm aware of. Ford used King Seeley systems after they changed over to electric gauges. The KS systems use a current regulator system in their senders. It always depends on what the indicator gauge was designed to function on. I have no idea what a 1930 Essex design used. The original 1932 systems weren't even electric. They were hydrostatic.
