1932 front axle
Peterooster
Is there any place in New Jersey that will recondition my front axle from my 32 pickup. The spring perch had loosened and opened the axle hole for perch by about .060". I am hoping a shop can install a sleeve to correct it. Pete
Any good machine shop should be able to do that.
Exactly. No need to ship it halfway across the country. Might as well have your kingpin bores checked and fixed, if needed, while you're at it.
A machine shop will not check camber and alignment of the axle. If you want an axle restored to new specs rather than just repaired,The axle guys will do that.
John
