- City
- Litchfield
- State
- NH
- Price
- $2700.00
1932 Ford V8 Engine and transmission
First $2700.00 gets it. Need the room!
I am relisting this and it is being sold as you see it minus the front engine mounts. Several people asked about the engine alone and transmission so that is how it is being sold!
You are buying the engine as seen without the front motor mounts. Included is the original transmission and shift tower as well, and aluminum oil pan that is on the engine.
Here is an original 1932 Ford V8 engine. It does have a 33-34 distributor and 33-34 intake and carb. This is the correct engine for the 1932 ford V8 purist. This was taken out of an original 1932 ford a while back and body was damaged on the car so the car was parted out. This is the correct 32 V8 engine that was built for this year only. It has the straight down water petcocks and the solid front face of the engine block. I have the 1932 oil filler spout and cap original for the 32 engine set up. This engine is free and turns with a crank. I am not an engine expert so I will leave that to you 1932 ford experts. It does have the original rare 1932 Ford Aluminum oil pan on it and it is in very nice shape no holes or break anywhere I can see. The oil dip stick is on the drivers side and in the middle of the engine. It has the original very nice transmission that was in this car with this engine as well. I just took the transmission off the engine to transport it. Clutch is still connected to the engine. Has the shift tower for the transmission also and lever. This also comes with the original 1932 Transmission complete as you see in the photos. Selling this engine as is no warranties and no returns.Also has original 1932 heads with the 18- part numbers on them. Numbers on Transmission are 18-49522 and I am being told this is a mid year 1932 engine. Also have the original petcocks straight down on engine, and tall waterpumps correct for 1932. Correct engine water outlets are on this engine and correct for 1932. Also have the original 1932 spark plug wire looms that came on this engine. Original 1932 Exhaust manifolds are still on this engine. This is being sold with the items you see and items that are in this listing.
Buyer to pickup engine or pay for shipping which will be determined once sale is complete.
Thanks
Chuck
603-429-0919
Thanks
Chuck
603-429-0919
