1932 Ford V8 engine, complete, rebuilt, aluminum pan
1906 REO
New member
Atascadero
CA
Price
$5000
Selling for a friends estate, a complete and fully rebuilt 1932 V8 Ford engine. The block is a real nice correct and straight one, NO cracks, bored .030" oversize. Flat top pistons. NOS Ford valves and bearings. Rebuilt by local V8 Guru Warren "Hoke" Hokinson some years back, and never run. This was the original engine from a car that was sold years ago. It has th proper comonents, cast aluminum oil pan, correct manifold with carburetor, screw post generator, fan, and weirdo fuel pump.It has the exhaust manifolds, flywheel, waterpumps, water outlets/motor mounts, and cast iron cylinder heads with 7/8" spark plugs. The ONLY two things I see that are missing is the correct distributor and coil, although a slightly later one is present, and its missing the helmet air cleaner. Some extra engine bits go with it, exhaust manifolds, wire looms, oil pump etc. Price, $5000. Let's see you go find a good one and rebuild it for that kind of money. FOB Atascadero, CA. Call Jeff
daytimes, (805) 674-9225, cell.
