1932 ford two door sedan body
Common sense will tell you the top was welded in after the body was assembled. The 1/4 panels were stamped as one piece with part of the roof. To stamp the roof and both 1/4 panels in one die as one piece , they would still be working on the tooling for the first one. If they can stamp a 32 Ford 1/4 in one piece, the can stamp anything. It was not practical to have a steel roof on low prodduction vehicles. Where the production numbers increase, the hand labor reduces and the tooling increases. It has always been that way.If they were going to put a solid top on the 32 Ford , or any other car they would have the weld seam in the drain rail area and the top would have a belly in it. I made steel stampings for 50 years and I have a rough idea how the process works and so do most other people Thank you Don Babb
Well whats the verdict on this were pretty sure that it came from overseas so did they use different ideas over there or what?????????
