DavidG
It's BV-39 as shown below and they show up from time to time on ebay, etc., but the job can be done without it with some ingenuity using readily available materials such as wooden coffee stirrers or Popsicle sticks.
You'll figure it out when you reach that point.
Be careful when removing the ring from the hub as there are steel balls backed up with springs inserted into the sides of the hub perimeter. If you remove the ring without covering it all with a rag, for example, the balls will end up in the four corners of your garage.
