Hellu What we have here is a 1932 fordor seat assembly. The stamped curving back wraps around and forms the sides and the slightly arched top are 4door. The 5w have seperate side stampings (metal) that are spot welded to the botom and are basically flat . 3w sides are made of plywood. Both 3w & 5w backs are hardwood slats aprox 5 or 6 pcs. At the top the 3w & 5w are straight not arched (yours) also the steel upper sides ange outwards on the 4dr so are wider and will not fit in a 5w body.. the bottom stamping is steel (where seat tracks attacch) are the same for 4dr & 5w The 3w is similar, but is longer front to back and uses longer seat tracks. The 4dr back had crimped in "D" nuts for the robe rail attachments but this is a minor detail. Nice item, good luck with your sale Pete
