1932 Ford RUNNING Original "B" chassis
Jason M.
Seattle
WA
Price
5600
Fast track your '32 build with this great old chassis COMPLETE and ORIGINAL and perfectly suited to using as is with some easy elbow grease clean up type work.
Runs well, rolls and steers, would drive with a firewall and throttle pedal added, ready to drop a body on and go, only non 32 piece is the front axle (33/36 type). Good 5.50 17 Denman wide whites and mechanical brakes and nice, useable original fuel tank.
Engine, gearbox, axles, radiator, steering, pedals, linkages, charging system, battery tray etc all held together with original FORD hardware, keys in the ignition. Last run on street in 1964, stored indoors (Oregon) until 2009, it's been outside sort of covered for 3 years now and does need to be cleaned up, fluids changed etc but was running STRONG and smooth October 9 2012 with NO coolant or oil leaks.
This is not a mint piece but was a nice old west coast car, the original panel truck sheetmetal is now back on the street in as found condition. The frame rails are STRAIGHT and clean, has an OLD weld on one rail and the rear crossmember has been welded on, these repairs are old and do not need attention if you want a quick build.
NO PAPERWORK included. Come and roll it on your trailer or flatdeck.
YOUTUBE http://youtu.be/iz7v68RgC7M
