1932 Ford roadster project brookville
OldBolts
Delafield
WI
Price
28000.00
Titled as '32 Ford Roadster using the original numbers stamped on the frame. Engine is mounted in frame with brackets I made. I have the rear half of a'40 Ford cross member.
Itemized list below. Not separating.
1932 Ford Brookville body flat floor with tack strip
Windshield frame - 2" chop
stantions - set of chrome and bronze
grill and shell
hood
rebuilt '39 3 speed with '46 gears & new mount
engine - 59 ab, winfield cam, merc crank, .40 over, johnson lifters, 1500 miles
walker radiator
new rodsville quick change
gas tank
head lights - blc 682
tires and wheels - firestone 7.00 & 4.50
40 rear end with bones
brakes redone (drums turned, new cylinders & shoes - '40 ford
shortened torque tube & drive shaft - '40 ford
wishbone & speedway tie rods
spindles - round back heated and bent
column tube & drop -'40 ford
steering box - '56 truck
heads - new block letter, higher compresson ones, two options
intake - new Edelbrock sling shot
kwik top - new in box Speedway
hood latches and handle
39 drake tail lights - new
amc dual master cylinder new (fittings fit ouboard- pedals and brackets made for it to work
new SW wing gauges and panel - panel made by HAMB member
shortened mini van seat
Stock frame with model A cross members & original K member
misc, headlight bar, f1 shock mounts, new wheel bearings, extra set of new brake cylinders, and more
