1932 Ford roadster hot rod project
OldBolts
Delafield
Wi
Price
24000
Titled as '32 Ford Roadster using the original numbers stamped on the frame. Engine is mounted in frame with brackets I made. I have the rear half of a'40 Ford cross member.
Itemized list below. Not separating.
1932 Ford Brookville body flat floor with tack strip
Windshield frame - 2" chop
stantions - set of chrome and bronze
grill and shell
hood
rebuilt '39 3 speed with '46 gears & new mount
engine - 59 ab, winfield cam, merc crank, .40 over, johnson lifters, 1500 miles
walker radiator
new rodsville quick change
gas tank
head lights - blc 682
tires and wheels - firestone 7.00 & 4.50
40 rear end with bones
brakes redone (drums turned, new cylinders & shoes - '40 ford
shortened torque tube & drive shaft - '40 ford
wishbone & speedway tie rods
spindles - round back heated and bent
column tube & drop -'40 ford
steering box - '56 truck
heads - new block letter, higher compresson ones, two options
intake - new Edelbrock sling shot
kwik top - new in box Speedway
hood latches and handle
39 drake tail lights - new
amc dual master cylinder new (fittings fit ouboard- pedals and brackets made for it to work
new SW wing gauges and panel - panel made by HAMB member
shortened mini van seat
Stock frame with model A cross members & original K member
misc, headlight bar, f1 shock mounts, new wheel bearings, extra set of new brake cylinders, and more
CLICK HERE! https://photos.app.goo.gl/2Tg4RgRuo5jSuCwv5
