37 Coupe
I have been on Fordbarn for years and allways with Flathead V8 questions. This Model B is new to me and hopefully I am not making a nuisance of myself but many questions and issues. The engine is a Schwalms rebabbit rebuild with supposedly only a couple hundred miles on it.Great running engine but really bad oil pan leakage. NOT Schwalms doing to make that clear but the owner who had the rebuild done. I think he bought it as a short block and put it together including the oil pan. For some reason as he had told me he installed the engine with pan off and then did the hard work underneath without a lift and had trouble so gasket and mayby the seals are comprimised. So gonna be my winter project and questions are am I missing something here,oil pan needs placed after install the block in frame? I am sure Ford dropped the entire engine together in assembly line. But is there something that will be an obstacle with back of pan? I put a Model A engine together just 5 years ago and placed in frame with pan on.Same with many V8 but no expierience with the B clutch housing and rear damper on firewall. It leaks really bad all around the surface engine to pan. hopefully windage tray is in place if that would even create this issue. I don't have a lift either but I can get it raised quite a bit or bite the bullet and pull it out? Like I said it runs great and smooth just really leaks,not just a drop but a pretty good puddle each startup. Thanks for any advice.
