deuce-deacon
Thanks in advance for help with this.
I'm restoring two headlights from a '32. I've been able to remove the inner trim ring by grinding out the tiny spot welds.
And now the obvious question. What do restorers do to re-attach the new replacement rings? Spot weld or solder them? Use rivets? Use small screws/nuts? Use nothing?
I'd sure appreciate an answer as to what would be the best approach based on members' experience with replacement rings.
