1932 Ford Frame
Hello I have the rear of an original 32 frame From about 30 inches ahead of the rear crossmember (has crossmember) to the back. rear horns are good never bent ,cut welded ect crossmember still riveted in ,Not cut cracked bent ect . They have rust but I think a sandblast and filler primer would work. I used the k-member to fix my frame so i'm sure there usable. If interested email me at pyoss@wi.rr.com or call me (414)543-8666 ornings are best for calling Thanks pete
Tom, ASC will sell you firewall forward frame pieces. You probably can just buy the left side alone. They also sell just the horns from about at the crossmember forward. That is what I did. They also sell the rear horns from the crossmember back.
