Greetings
I would like information regarding assembling a 32 frame using original cross members, repo rails, 59a engine, early transmission, and closed rear end. I have ordered correct rivets for assembly.
Proper for and aft attachment of the center K member can be done from frame drawings, but how do you determine if the trans mount flat on the K member is 90 degrees to the top or bottom of the frame rails? Inserting the engine and transmission would help but if using the later engine and not using the original engine front mounts could lead to improper front engine height. I have searched and seems the center line of the engine crank should be 2 1/4" below the top of frame rails.
I am planning hydraulic brakes, using original pedals, but don't like the low placement of the master cylinder, Have considered using a bell crank assembly and turning the master cylinder 90 degrees to the center line of the chassis. I want to eliminate any areas where a rock could lock up the brake linkage.
Also consider using 32 dropped front axle, original spindles, unsplit wishbone. Question, am I going to run into interference with the tie rod and wishbone? If so, how is this corrected? Dropped tie rod? Previously, I have used modified spindles reversing the tie rod to clear wishbone. I do not recall interference with pan and tie rod or frame.
Where could I acquire king pins with the 32 brake socket removed that would be adequate to support the weight of the vehicle?
I may also use a dropped 40 rear cross member if I determine using a 35-40 rear end.
This asks a lot of questions, and I would appreciate your comments.
Thanks
Jack
Thanks
Jack
