1932 ford chassis
hopped up flathead
racine
WI
Price
6500
On the fence about selling but here is what I have, frame fresh out of jig, original crossmembers, repop rails, heavy axle, spindles, juicers front and back, 32 rear end, repop steel gas tank, trans case, 39 gears that need to be put in case, steering box and 1/3 of the shaft, NOS drag link, pedal assembly, freshly powder coated 35 wires, NO TIRES, no tie rod, no wishbone, no rear spring. HAS TITLE, 32 roadster. I found something I would like to buy so I either need to sell this or forget about the new item! Thanks Everything is apart, front end parts are freshly painted, everything else is either primer or original finish.
