1932 Ford Alternator options
WRA
I have a 1932 Ford B with Cragar head that has been converted to 12V and I'm looking for alternator options.
I see that Powermaster Performance make an 12V alternator in stock appearance for the Model A. Would this work for the B Motor?
Product: Powermaster 82001 - Powermaster PowerGEN Alternators
What are my alternator options that retain a semi stock or period appearance.
If Powermaster alternators are anything like the Powermaster 12 volt starter I had in my 8ba, run away. The starter was a POS. JMO
Powermaster's in general do not have much of a fan club around here. I've not any, but search some old threads for some sad story's.
Another vote for Whitney. He converted mine 16 years ago, and it's still going strong. I sent him the end plates only, and he did the rest.
FWIW. Saw this guy on Jay Leno's garage. He puts an alternator inside your stock generator housing. Doesn't cost anything to inquire. He advertises monthly in Hemmings.
Gener-nator
www.gener-nator.com
541-902-2255
He's in Oregon.
Thats intersting tom, wonder what he is using for the guts. When I talked to Tom whitney, he would not tell the secret of what they use. I asked if its common stuff that an alternator shop would be able to replace years down the road he assured me yes, its common stuff. Many folks theorize its a Kubota unit, they are small. As 4dford above states, they only need the end plates (Talkin v8's here) and the center section is a new part, aluminum, and slightly larger in diameter to the original gennie. You would not know on first glance. The next problem is the front bearing on the units that hold a fan. Powermasters, and stock delcos have been known to break off and send a fan thru the hood. Whitney told me thats not a problem with they're product, but I dont know what they have goin on there. mine only has about 5 k miles on it, so no bragging rights yet. Coopman here made his own, I forget the details, but it has been posted here if you are a do it yourselfer
Cas I'd guess it's not really a secret. More about someone that is willing to do it and make a good product. Guess it's a question of what you want to get into. Better mouse trap as they say.
Years ago I made 9 6 volt alternators using 39 shells and
nippendenzo 12 volt small tractor alternator parts. I purchased
the parts from Chestnut Hill Electric Motor Supply in Denver, Pa.
I also used a 24 volt comutator so it would putout max powrer
at idle at idle with a standard size 39 Ford pulley. I installed a
bridge rectifier and variable voltage control to set the voltage
at idle speeds. This was over 10 years ago and have had no
failures and they all still work good. G.M.
